Which battery option will suit your purposes best?
    164
BTW, have they said the difference in the weight of the two batteries?
As of five days ago:
Kylee from the Sales Agent Team gave a prompt and courteous reply.
Excellent questions!​
We are just a few months shy of our production and sharing more design and material details about the overall build.​
While I would love to provide the detail you are in search of we ask that you hold tight. We have many things in store.​
There have been tests that show that weight alone has almost no effect on efficiency or range. I’d be surprised if there was much difference at all in efficiency between the two battery sizes
The [mis]calculation is was based on published specifications [and faulty cyphering].
Published estimates. But yes, I understand where the numbers come from.
Maybe I should have chosen a better word.
Slate is claiming, by publishing those numbers, that the same energy that gets you 100 miles with a Standard battery only gets you 89.3 miles if you have an Extended battery.
I wouldn't call that negligible.
Slate is claiming, but publishing those numbers, that the same energy that gets you 100 miles with a Standard battery only gets you 89.3 miles if you have an Extended battery.
For sure. That’s why I’m dubious of those claims. Based on every other EV in existence, I also expect to get about 12% less range than their EPA estimates, if not even less.
It's more difference than you'd expect, yes.
[Edit: and for good reason! Miscalculation.]
Another way of looking at it:
If you can get 40 miles of range on an overnight 110v charge of a Standard battery, the same charge would only get you 35.7 miles if you have an Extended battery.
Advantage: Standard
We just aren't going to find out anything more on range and battery pricing for at least a few months, the numbers we have seen are estimated EPA estimates coming from a computer model. Once they build the actual first final version trucks on the assembly line, they will be tested and real EPA estimated mileage numbers will be released.
The one part that will be disappointing I think is wind resistance. Most EVs besides the large pickups are highly streamlined, and the slate is going to suffer at high speeds more than them. Stop and go traffic will be fine, because of regenerative braking, but the faster you go the more wind drag.
Big time.
Among all of the Battery Buzzkills I've looked into, highway-speed driving is the biggest surprise.
As speed doubles, the power needed to overcome drag increases by a factor of eight.​
Driving at high speeds affects EV range waaay more than I expected.
The shape of the Slate Truck is not exactly that of a Land Speed Racecar.
Surely the engineers know Drag Coefficient (Cd) for the Truck. I wonder if that information will be published.
Big time.
This got me looking at how the EPA range is determined, they test on a dyno, and run a city cycle, and a highway cycle, they typically multiply by 0.7 to account for AC use and aggressive driving, and they weight the city at 55% and highway 45% and give 1 combined range number. Looking beyond that it gets really technical.
Try again. :giggle:
Ha! Well, that's embarrassing. 🤦
I took your advice and tried again.
Sure enough, it's negligible (rounds to zero, favors Extended).
240 miles on 84.2 kWh is 2.8503 miles per kWh.
150 miles on 52.7 kWh is 2.8463 miles per kWh.
2.8503 divided by 2.8463 is 1.0014
So Slate's published figures cypher to 0.14% more range (1.4 miles per 1,000) with the Extended Battery option.
Regarding acceleration...
My not-so-educated guess is that the Extended Battery option adds 300-400 lbs of weight.
If so, another guess would be that it slows the 8.0sec 0-60mph time to more like 8.4 or 8.5 seconds.
If that's right, and the two were to race, by the time the Extended Battery Truck gets to 60mph the Standard Battery Truck would be something like 40-50 feet ahead.
DanDibs58
Dan
Central New Jersey USA
2021 Tesla Model Y LR
For me, it depends on what my other vehicle is or if we have another one. Assuming it's a longer range EV, like my current Tesla Model Y LR, I may opt for the cheaper battery and just use this for around town stuff. If we end up going with just a single car in retirement, then Slate is out since we do road trips pretty frequently.
The Extended Battery option is projected to weight 302 pounds.
My guess is that it adds .4 seconds to the 0-60mph time.
Having an alternative vehicle with features missing from the Truck (range being the example here) makes a big difference.
The Extended option doesn't simply add "Magical Extra Range".
Maybe reducing payload capacity by the weight of the battery from 1,433 to 1,131 pounds is significant for your purposes.
Maybe slowing your zero-to-speed-limit times makes a Fun Factor difference you care about.
Most of the thousands of dollars the Extended Battery option costs are not recoverable at resale, so there's that too.
