Max speed - 90mph?
Visualvalhalla
Andrew
Is the Slate highest speed locked to 90mph due to the motor or the gear ratio? We have some highways in Texas with a 85mph speed limit, which means cars are whizzing past 90mph.
With EVs, it's usually a combination of battery, BMS, motor, and of course reduction gearing. People are often surprised that the battery itself is often the limiting factor. A given battery can only deliver power at a given safe rate. Cells are chemical machines that generate heat.
This thing is really pretty small. I don’t see me running this up and down the highway, other than a few local miles getting to town.
usbritinusa
Dave
Connecticut
2024 Ford Bronco Heritage 4dr Robin Egg Blue
Agreed. 90 mph is fine for me but I do wish it was a little quicker on 0-60…but I guess 8 secs is ok.
GrizzlysGhost
Montana
Many, many vehicles are 98.
Yep, my H3 has a speed limiter around 98, though I did get it over 100 a few times. I had it in The Netherlands with me for a couple of years (Autobahn).
90 is more than enough for my Slate.
My first car had a 0-60 of 18 second's… and 80 hp, top speed may have been 80 with a tail wind going down hill.
I feel like the main concern is whether acceleration will get a lot worse as you approach 90.
I imagine it's mostly drag, based on the Slate's profile and my (vague) memory that the Slate was previously given a top speed around 90 before motor output went from 200 -> 180 horsepower (or as presented by Slate, 150 -> 135 communist horsepower /j) with the lower voltage of LFP cells; meaning, it's probably not limited by the amount of energy (heat) being put into the motor.
Assuming acceleration doesn't drop off too harshly in the upper freeway ranges (60-85?) in general, it sounds fine. I think in the recent driving tests with journalists and Chris Barman chatting, she mentioned it's optimized for the 30-60 range...
Faster than my car.
I think a lot of the noticeable "slowness" of a less-powerful ICEV isn't in the 0-60.
Internal combustion engines have to deal with overcoming vacuum (they're basically air pumps, in a lot of ways), reciporocating mass, and then their narrow power/efficiency bands mean you need a transmission.
The transmission adds a delay for shifting, and unless you're driving aggressively, automatics (or frugally-operated manuals) prefer upshifts away from power to improve fuel economy.
So, in a straight line, testing maximum acceleration, you get the 0-60. Coming off of a stoplight, there are a bunch of little delays and you're pulled away from your power by gearing.
Electric motors have their wide power and efficiency bands and don't need a transmission (or emissions optimizations; I hear that can add further delay in some cases), so you should be getting the "0-60" acceleration in real-world use.
DT444T
Earth
I had a 2.0 TDi Jetta Sportwagen. It did 0-60 probably in that 8 seconds range, even with a tune and exhaust. Still PLENTY quick for getting out of the way.
Eight seconds seems fine, to me.
And I'll have the cruise set at 70-73mph. Go around me, the right lane is mine.
About 99.99% certain my Slate will never see 90 mph. My Tundra hasn’t, wife’s Ascent hasn’t.
