Here is the full article: Electrifying Review, reproduced / edited content below to fit within the confines of Slateforums.com
It's not going to be available in the UK market, but the reviewers are so intrigued they are lobbying for a European launch.
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review {filename}
The EV ExpertsTM
Slate Auto Review
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review thumbnail_GinnyBuckleyBlue
Reviewed by
Ginny Buckley
24 Nov 2025
A compact electric pickup with a twist: every
Slate Auto rolls off the production line looking identical and lets you adapt it with a range of different body styles - using an Ikea style flat pack kit - at a price that undercuts most EVs on sale today.
  • Pros: Incredibly customisable, affordable, compact size
  • Cons: Modest range and efficiency, low payload, simple interior divides opinion
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review Ginny%20Slate%201
Introduction and model history
Slate Auto is the latest electric disruptor to emerge from the United States - and it has some big names behind it. Based in Michigan, the heartland of American automotive manufacturing, the company is backed by investors including Amazon founder Jeff Bezos. The team itself brings credibility with its CEO - Chris Barman - a Chrysler veteran with almost 20 years under her belt, while Slate’s head of design Tisha Johnson spent 17 years at Volvo. The Slate Truck is their first model: a compact electric pickup designed with modularity at its core.
The big idea? When it rolls off the production line, every Slate will be basic grey and identical. Until you get your hands on it and then it becomes whatever you want it to be. Fancy an SUV? Prefer a fastback? Maybe a beach buggy? No problem, there’s an Ikea style flat pack you can order and simply bolt onto the back to transform your vehicle - the team assured me you won’t need a set of spanners or an engineering background to fit the packs at home.
There’s also a whole world of different coloured wraps, decals, accessories and upgrades to play around with. Think of it as Lego for grown-ups: Slate gives you the pieces, and you put it together.
Sized at around 4.4 metres long, it’s nearly a metre shorter than conventional pickups such as the Ford Ranger or Toyota Hilux, making it more manoeuvrable and better suited to urban and suburban life. In a US market that buys nearly three million pickups a year, Slate is aiming to carve out a niche with something fresh, affordable and customisable - this is the polar opposite of the Cybertruck.
Building just one basic body style should make production - which is due to start in Autumn 2026 - quicker and simpler. Slates factory is being built in Indiana, right in the American Midwest – handy when you’ve got a president keen on import tariffs. Even the NMC battery cells come from a Korean supplier, which will ultimately be built in a US plant. The first customers should receive cars towards the end of 2026.
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review Ginny%20Slate%204
Range, battery and charging
Two battery options are available: a standard 53kWh pack offering around 150 miles of real-world range, and an 84kWh upgrade extending that to roughly 240 miles. Those numbers won’t trouble long-range EV SUVs or trucks, but Slate’s compact proportions and lightweight construction make the most of the energy on board.
Charging performance is solid rather than spectacular. The onboard 11kW AC charger suits home or workplace charging, while DC fast charging peaks at 120kW, allowing meaningful top-ups on longer journeys.
The charging port is conveniently positioned, and although Slate hasn’t confirmed features like vehicle-to-load, the platform has been designed with modular upgrades in mind. The use of NMC battery chemistry should also offer good efficiency and energy density for this class of vehicle.
Practicality and boot space
Think of the Slate as a “diet pickup”. It captures the shape and spirit of a truck, but with far less weight and capacity. Payload tops out at 650kg - significantly lower than workhorses like the Ford Ranger - but still enough for DIY duties, outdoor kit, bikes, camping gear and most lifestyle users.
The flat bed is wide and easy to load, and switching from truck to SUV or fastback configurations simply involves removing the rear screen, installing the modular kit and clipping the screen back into place. Safety has been carefully considered too: if you add rear seats, the roll cage accessory includes integrated airbags and sensors that prevent the vehicle from operating unless everything is correctly installed.
The lightweight plastic body panels are 3D printed and fully replaceable, meaning repairs, upgrading and restyling should be cheap and easy. If you want your Slate to look different every year - or change with the seasons - you can make it happen.
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review Blank%20Slate%20-%20Profile_web
Interior, design/styling and technology
Inside, the Slate is a celebration of simplicity. If you miss the days of straightforward dashboards and physical buttons, this will feel like a breath of fresh air. There’s no giant central screen and no complicated infotainment system; instead, your phone is expected to handle navigation and media, with an optional iPad mount available.
Manual window winders return (yes, really), though electric windows can be added as aftermarket accessories - you can even spec one for you and leave the passenger with a winder!. A small digital cluster provides essential information, including the feed from the mandatory (in the US) reversing camera, as the Slate has no central display.
Quality is intentionally functional rather than plush. Storage is good - if you want to spec it - while the seats are comfortable enough for commuting. It won’t be to everyone’s taste, but that’s the point - Slate is giving buyers a blank canvas.
Motors, performance and handling
Power comes from a single rear-drive motor delivering 200hp, more than enough for a compact pickup. The 0–60mph time of around eight seconds is genuinely respectable, and the low weight should help the Slate feel nippy around town.
Ride and handling will be tuned for comfort and simplicity rather than high-performance thrills, but the relatively small footprint means it’s easier to park and thread through tighter roads than full-sized pickups. Chunky tyres and optional accessories like tow bars and running boards add visual toughness without compromising usability.
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review _Hero%20Blank%20Slate%20and%20SUV_web
Running costs and pricing
The headline figure is extraordinary: Slate aims to sell the truck for under $25,000, making it one of the most affordable EVs in America and by far the cheapest electric pickup. Even with the large battery and body-kit options (around $5,000 for a full SUV or fastback kit), it dramatically undercuts rivals.
But the temptation to spec your Slate with decals and accessories will no doubt push the price up for most buyers.
Finance costs should be low thanks to the simple construction, and running costs will benefit from the efficient motor and lightweight plastic body panels - which can easily be swapped out at low cost if you prang one.
Once fully launched, UK pricing and warranty details will be key, but the early signs point to a genuinely low-cost, low-stress electric ownership proposition.
Verdict
The Slate Auto pickup is an idea the car industry should have come up with years ago: a small, light, affordable EV that owners can configure, rebuild and redesign as often as they like. It delivers something fun and engaging in a market often dominated by overly complicated, overly expensive - and overly large - EVs.
No, it won’t suit builders hauling one-tonne payloads or drivers covering hundreds of miles a day. But that isn’t the point. Slate is building a lifestyle EV for ordinary people, and doing it with charm, creativity and genuine innovation.
If it hits its price target and delivers on its promises, the Slate could become one of the most influential electric vehicles of the decade. And yes - I’m already lobbying the Slate team for a European launch.
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review Blank-Slate---Interior_web
Electrifying.com score
9/10
A clever, customisable electric pickup that unlike anything you’ve seen before, at a price ordinary buyers can actually afford.
  • Battery size: 53–84kWh
  • Miles per kWh: 2.86
  • E-Rating™: C
  • Max charge rate: 120 kW
  • Range: 150–240 miles WLTP (est)
Ginny Says
“The irony of one of the world’s richest men backing such an affordable EV isn’t lost on me - but Bezos seems onto a winner. The Slate is the coolest vehicle I’ve seen in a long time, with adaptability and affordability in equal measure. Its range is modest, yet its charm is irresistible.”
Nicola Says
“Slate Auto’s debut is a refreshing antidote to increasingly complex vehicles. Small, light and uniquely customisable, it’s more lifestyle and less load-lugger yet its sub-$25,000 price tag gives it potential to become one of the decade’s most influential electric vehicles.”
Slate Auto Pickup Truck Slate truck reviewed by UK outlet (Electrifying.com) - Updated with video review NicSite
https://www.electrifying.com/news
Sadly, this isnt much more than a puff piece. It's 99-44/100% recycled material reworded to sound fresh.
Only "new" material were the comments on ride dynamics - and even those were general inferences not based on driving the thing.
I'm not even sure the reviewer wasn't AI pasted over a stock Slate image.
EtA deep link...
https://www.electrifying.com/reviews/slate-auto/pick-up/review
First outlet I’ve seen with an efficiency rating. It scored a C which I would say is accurate with an estimated efficiency of less than 3 miles per kWh.
Their rating criteria is chock full weasel-words and ambiguity. From their website...
The Electrifying.com Efficiency Rating, known as the E-Rating™, has been reviewed and verified by leading independent industry experts and is formulated using an algorithm that takes into account a number of factors; including how well the car converts electrical power into miles on the road, the speed at which the battery can be recharged and features such as energy saving heat pumps, intelligent brake recuperation and climate control preconditioning. There’s also a ‘secret sauce’ based on our expert team’s experience of driving, testing and reviewing electric cars in the real world.
Once again, recycled material - just repackaged to sound innovative. 96MPGe, 2.9mi/kW, 82.3kWh battery, 11kWh level 2 means more to me than "C". They even trademarked their grading system to make it extra useless.
If she was really next to a Slate, why not ask the people who brought it some questions? Any idea of drag coefficient? How much does range improve woth the fastback? How much do you lose with the flatback? How does raising and lowering affect range? Charger efficiency? Motor efficiency? Drive efficiency? Battery preconditioning? All the things reporters are supposed to ask.
Funny the Slate got a grade even without being driven, even though it's part of the "secret sauce".
This is a generic hands-off review based on info we've all known for months. Reporting without journalism. Maybe I should copyright that.
2018 Tesla Model 3
Well to you and I, 2.9/kWh means something but to the lay person probably not. By stating efficiency is a ‘C’ it probably tells a much wider audience that the efficiency of this vehicle is mediocre, not good with a rating of ‘B’ or great with a rating of ‘A’
Any and every article or video that comes out right now is going to be restating the same stuff, because Slate isn't releasing "NEW" stuff. They are however giving the info to new audiences that haven't seen it before. This article isn't targeted at us here, who have already seen all the articles that are already out.
The people there don't know the drag coefficient or other details, the engineers or executives with that info aren't there, and wouldn't be allowed to release unreleased info anyway.
I don't expect that we will see anything "NEW" for a month or 2, sometime early next year they will start putting out more info.
I'm not even worried about that kind of detail until we get to within months of the release, when those details will be finalized and I have to actually make my final decision.
Middle of the Mid Atlantic
I really don't care about Bezos' connection to this thing.
The takeaway is that Slate is gaining international attention, and the universal appeal of the 2 door small truck platform. These are credits to Slates’s winning design. Aside from their unique E-rating system which warrants further discussion, we can all agree that no ‘breakthrough news’ was revealed.
Most of the interesting stuff will be happening at the assembly plant and behind closed doors of board meetings. What I will be watching for are the preproduction specs...right now even range is a "prototype guess". When they come out with real numbers it will show what their philosophy is; i.e. under promise and over deliver...or not. And the biggie...price.
Tran
Explorer
Here's a video of the Slate pickup being driving around getting into position for the article photos
Autoline After Hours briefly touched on Slate in this week's episode (4 Dec). At the very last minute of the show - in response to a viewer question. The guests were two industry analysts, one a former product planner at GM. Their take was really dour, for what it's worth. They questioned whether Slate has a valid business case without BEV incentives, and they questioned the demand, capital requirements, and plant utilization.
I'm insanely curious to see if the industry analysts are right or wrong. If they are right, Slate crashes and burns NLT the end of 2027., If they're wrong, then maybe Slate is a black swan event, selling out and having back orders for years (this was the Ford Maverick - multi year waits on early orders).
If only Carnac The Magnificent were still around to tell us how it's gonna go...
https://en.wikipedia.org/wiki/Carnac_the_Magnificent
Media analysts make their money by getting attention, and what gets attention is extreme pessimism followed by extreme optimism. Middle of the road opinions simply don't get the clicks and views. So they're almost always wrong because of this, and it's just luck when they're not. And they rely on those few times they are 'right-enough' to maintain their air of 'credibility'.
What they're analyzing is not a binary situation, it's a spectrum. The reality will all but inevitably fall somewhere in between.
MIDgrid
Olympic Penninsula, WA
Jeep Cherokee Trailhawk, Sprinter 3500 motorhome
Here's another UK article expressing interest in the Slate Truck:
https://www.independent.co.uk/cars/electric-vehicles/tesla-cybertruck-slate-truck-ev-b2878278.html
