Door vent wing windows
GreatLakes
F150 ‘16 supercab longbed! V8
Counter counterpoint. Usually car windows are in-line to the car. So if you drive fast, the air rushes by, but maybe doesn't come in. Or the front window blows into the back seat.
The vent window can be set to just allow some air in, or opened far enough to scoop the air in. You can direct it directly into the drivers face if you want.
But that manual crank is very sexy too. Very precise to put the window right where you want it. Unlike most of the power windows I've used - stop, stop, too far down. Up a little, oh too much. All while trying to drive.
All good points.
Would be great, but I suspect a not so minor rework.
Counter counter counter point. AC can be directed exactly where you want, and the temperature can be modified as well.
Additionally, Lake Superior> Lake Michigan
We very rarely use our AC, but sunroof most always open.
GreatLakes
Hmmm, ok, maybe you have a point about some benefits of AC. Certainly since '86 (our first AC car) and '99 (AC installed in house) we have sort of become reliant on it.
BUT, I'm going to share some of my TRUTHiness about the Great Lakes. In reality, there are only four, Michigan-Huron is one big lake. It is actually so big that people can't grasp the reality, but look at the 5 mile Straits separating the two basins. And the Great Lakes office only reports one water elevation figure for the one Greatest Lake.
This also makes Lake Michigan-Huron the largest freshwater lake in the world, instead of that dang commie one that is otherwise bigger than Superior.
slateya
Minnesota
Sorry to pour cold water. Items required to make this happen.
Different weather striping inside window opening. Two pieces. Triangle and roll up.
Structure post to form the triangle.
Triangle window (tempered)
Latch (as yet to be designated more theft resistant that last ones)
Roll up window. (Tempered)
Window slide rails and lift bracket (to fit smaller window)
Cannot cut existing window down. Tempered glass is not cut able. This is an expensive option to design and construct.
It’s not going to happen.
Baikal wins by volume, and even would if you connect Michigan and Huron. I believe (don’t fact check me) baikal has more volume than all the Great Lakes combined!
But Superior wins by surface area, even without mental gymnastics.
By your logic… can Superior join the mega lake, via sault st Marie? Or is the difference in water level enough to disqualify it?
Firstevexcited1
Ron
Chevrolet Silverado
So,I'll do it myself...it was just a wish list anyway like everything else on these threads. I'm a fabricator so it doesn't intimidate me. Glass can be cut...how silly.
Firstevexcited1
Ron
Chevrolet Silverado
AC takes battery power,vent window takes a small effort to open that's all...crank window will bring into the cab virtually little air. Have had wing windows my whole life...they work. Saving electricity for drive motor.
I have vent windows in my LTD and I love them. Rarely use them though. I have much less fond memories of Dodge D150s and the like growing up with ever-increasing amounts of cardboard wedged in the latch to keep the window shut as the seals aged.
While I think they're fun to have the second set of side windows and parts would probably keep Slate away from that concept in the near-term.
Slate Auto Pickup Truck Door vent wing windows 1748177686742-j
Hey, Bob, do me a favor and hold that window shut.
Sometimes it starts whistling when I get up around 50.
Do I have to hold this the whole trip?
No. Just while we’re going faster than 50.
I'm betting that the reason they disappeared from the automotive landscape is due to being outlawed by NHTSA or some other regulating entity. Likely too many people got direct shot of a bug in the eye and sued the manufacturer for negligence.
