What limits the Slate to 1000 pounds towing capacity?
Looks to be a couple things.
My guess would be a mix of range extension, electrical system capabilities vs towing and cooling, and from what ive seen, lack of a proper frame to hitch with. Seems to be a bumper hitch.
Price point and type of body doesnt determine towing. Ability to stop, steer, shift (or in this case just move) and move are generally what does. Once you get away from those things, vehicle weight is usually the limiting factor.
I will say the towing on this is ridiculously low. I used to have a '13 Focus SE and that was rated at 1000 towing. Im guessing the slate's towing is more of a butt covering measure than anything.
From what I can find, the focus wasn't tow rated in the US. Doesn't mean you can't tow, and in other countries it apparently was tow rated, but for comparison to the anticipated 1000 lb US tow rating of the slate, the focus was a zero.
Looks like no tow rating means if you tow with it, and there is any damage that even looks like it might be tow related, it's not going to be covered by the warrantee.
We just don't have any details on towing with the slate besides that number, no one's even seen one with a hitch receiver visible, or a sign of where one would be or mount.
I'll throw in that the BMW X6, when opting for the 'Tow Package' includes frame gussets, not just trans/cooler/tow harness stuff. SO if you add a wiring harness and tow funtion later, you still don't have all the needed parts to get to where the factory would have put you.
Also, no ones mentioned wheel base. Just cause you got the grunt and frame, doesn't mean you can handle the weight. Too small a wheel base and the trailer will drive YOU, not the other way around!
My take:
The reason the Truck can only pull 1,000 pounds is because it's an economy car, either in a pickup or an SUV form factor, with as little as 820 pounds of load-carrying capacity.
Economy cars don't pull heavy trailers.
Edit: To put it another way, it's not some specific Truck attribute, it's just the nature of this particular beast, because low price (cost-of-ownership) is a top priority in its design.
This makes me wonder if Slate is positioning it with that tow ability to keep it inside some government tax or incentive windows? It might be a 'limit' just for the limit's sake so they get a financial break somewhere. It's not like they would tell us if that was the case.... :/
Could be.
I think it's because the initial Truck prioritizes economy in its design, leaving room for more grrr in a later, more expensive version.
Admittedly that could be some Wishful Thinking happening on my part. :) I'd happily pay extra for AWD and 500# more load / towing capacities.
I haven't seen anything like that related to tow capacity. In many states apparently, if it has a bed then it's primarily for transporting cargo, so it's a truck, and you pay extra for commercial registration. You can get around it with a camper shell (or in slate's case, an SUV kit) but you have to install it, and at least certify to the state that you don't plan to remove it. It's not a huge difference in fees anyway.
Part of the fees are based on vehicle weight, but not on capacity.
According to the California DMV part of the fee is based on:
  • The unladen or declared gross vehicle weight (GVW) and the number of axles your vehicle may have.
They also have a fee calculator, For pickups, you have to choose commercial.
Checking, and for under 10k lbs you choose the unladen weight range, the lowest range is under 6k lbs, slate is supposed to be around 3602, so it wouldn't matter what you add, you shouldn't be going over 6000
Tax on 27500 would be $2681, registration fees would be 519, for 3200 even. $179 of that is tax deductible, If I pretend I'm getting the SUV kit and registering it as an auto, registration drops to 432, the difference is a California weight fee of $87. The only weight entered is "up to 6000"
Wow, learned something new. That's a very California way to do it.
In Arizona (and federally) GVWR (with an R) is used, not GVW.
In AZ even a 3/4-ton pickup isn't automatically commercial.
Passenger cars, ¾ ton or less pickup trucks and ¾ ton or less vans, used for commercial purposes 1,000 or more hours in a vehicle registration year, must be registered commercially.​
Every state is different. Even counties and cities can have different stipulations.
Here in WI for example trailers don't have to be licensed, insured, marked, or even 'approved' for use. I passed one on the freeway last year that had 10 speed tires on a wooden box; looked like the base of it was a pallet maybe. They were doing about 70 in the left lane. I did NOT want to be behind that!...
I asked them about towing, and they said:
Yes, the Slate truck will have a tow hitch accessory, however we are still expanding our accessory and add-on portfolio at this time. Please keep an eye out for our newsletter (you're opted in) for all the latest news and product updates. (May 3, 2025)
Many Mustang GT's had the same basic engine, transmission, axle, and even brakes as an F-150, but still only a 1000 lb tow rating.
rmay635703
Ryan
wisconsin
Chevy Volt Premium
Weight and lever arm, is the main factor even on a shorty.
we have stubby single seat single axle semis towing dual 80,000lb trailers around town between factories, docks and lots and they are only as long as my antique pickup.
seen them going 55mph occasionally so not sure 80mph would be a good idea, but they aren’t unstable or flying off roads either.
generally the closer the rear axle is to the hitch the more stable things are, when you have an overhang that is we’re the trailer gets lever arm forces which drives a beefier and heavier front end combined with a longer wheelbase.
^This, I know a few people who have towed pretty big trailers with Crown Vics just by putting the bigger hitch on it and a brake controller, but the factory package included a whole lot more:
Slate Auto Pickup Truck What limits the Slate to 1000 pounds towing capacity? 1757468747281-st
My guess is that a hitch receiver that mounts to the frame will come through a port in the bumper below the license plate notch.
On this bumper? How would that work?
That is a step bumper. Trailer ball bolts through hole in the horizontal surface below the license plate. Every truck I have owned has had a very similar bumper with holes in it to mount the trailer ball. It is only rated at 1000 pounds, the step bumper is good for it.
