Carpet in the Cab, Why??
MIDgrid
Olympic Penninsula, WA
In yesterday's Q&A with CEO Chris Barman I'm pretty sure I heard that carpet would be standard for the cab floor. This is surprising since there is IMO a much better option already listed in the Slate Maker: Rubber Floor Liner. I've always disliked the standard auto carpet liners as they are hard to keep clean. I was looking forward to a simple, easy to clean floor liner in this function-first simple Slate Truck - similar to the standard Honda Element non-carpet "utility" floor. Adding rubber mats over carpet is not ideal.
Now I'm concerned that I can't order a plain Slate Truck without having to specify the rubber floor liner option, or possibly DIY rip out the carpet later to install the rubber floor liner - this is my first disappointment. Slate seems to have lost their "intentionally simple and utilitarian" blank slate vision in this case.
R56, CX3, SA, C1500, E150
Indeed! With rubber mat over carpet, I still have to vacuum the carpet to remove the dirt and debris that fell through the gap. I am looking into buying an air blow gun to loosen things up before running the shop vac. 🤦
I had been laughing at one of the dismissive articles for criticizing the Slate Prototypes as "not even having carpet floors!", so I'm disappointed to hear it as well.
Who ever wanted carpet floors in a car? I don't get it. Is it for quietness?
I don't think you have to worry about "needing to specify" options, given the Blank Slate premise. You'd order the same truck either way and presumably install the optional rubber liner over whatever was included standard.
Choices for floor mats and floor liners in the website's Maker are
  • Rubber Floor Mat Insert
  • Carpet Floor Mat Insert
  • Rubber Floor Liner
  • Carpet Floor Liner
Presumably the liner(s) eliminate the gap you're concerned about.
Most Ford Explorer Sport Tracs came with rubber flooring in lieu of carpet. Someone I know has one and likes that feature.
Sandman614
2004 Honda Element
I would assume it is largely for cost and NVH
I don't expect the Slate to be super quiet out of the box, carpet will help with some of that resonance
We'll have to wait and see the actual details, because the maker shows 4 things, rubber mat, carpet mat, rubber liner, carpet liner, in addition to whatever the base is.
from what can be seen, the mats seem to be similar to common floormats, and the liners larger, more like the weathertech liners. Possibly the plan is weathertech liners.
Worse case scenario, the carpet could be pulled and rubber installed in about 10 minutes.
Ironman
Gerry
Alberta
2006 Dodge 3500, 2011 Ram Dakota
Yes, I am an old boomer who remembers pickup trucks with only rubber floor. Carpets were thought to be dumb ideas for a truck. BTW some rubber mats are better sound proofing that carpet.
The carpet does have one feature that is good. It does wick up moisture and not let it sit and rust the steel pan below. But in a composite body, that becomes a non-issue. I like the "pant saver" type of rubber mat that collects the snow and mud and you take it out and shake and dump it off.
Drain holes would be the ultimate fix for that like the wrangler has, espically with something like the full floor liners, where you just open the drains and hose it out.
