Range predictions
Revenant89
Revenant89
Plano, TX
2024 KIA EV6
Slated Blank Slate height: 69.3
Maverick Lobo height: 67.7
Maverick Lobo ground clearance: 7.4
Accord ground clearance: 5.3
Maverick Lobo is lower than a Blank Slate, but hardly 'low'. I can easily imagine lower than a Lobo. :devil:
It's tall because of the cab height but projected to be between 6-7" off the ground. Slamming it to the ground wouldn't give you much utility.
Well it's 69.3" normally, but you can get a 2" lowering kit. So, that would bring it to 67.3" which is a lower roofline than the Lobo.
Revenant89
Revenant89
Plano, TX
2024 KIA EV6
I didn't even see the lowering kit I thought it was only the 2" lift. Not enough wiggle room for me.
mattlach
Boston
Audi A6 Etron Quattro, VW ID.4 PRO S AWD.
To be fair, a 0.39 Cd is atrocious.
I mean, it is a truck, so that is kind of expected, but other vehicles I have experience with that do very well, like my Audi A6 E-Tron both has a 0.21 Cd and a smaller frontal swept area.
Because of this it gets about the same range on the highway as it does around town.
The Slate Truck- however - I'd expect will do pretty well around town at speeds of 45mph or below, but that the range will drop like a brick on the highway due to the drag.
I'd imagine in SUV configurations, especially the fastback configuration, the Cd will be a bit lower, and in that configuration it will do better.
TomFrank
Tom
Radnor, PA
Subaru Crosstrek 5M
The maker doesn't mention it now, but I seem to remember the lift kit was a 2" lift and the lowering kit was 1½" drop.
Wondering if adding a tonneau cover on the pickup will improve the Cd? Or not that much?
mattlach
Boston
I'll fully admit that while I am an engineer, I am not that kind of engineer. Aerodynamics are not my specialty by any stretch of the imagination, so I am more like a well read layman than an expert on this topic.
That said, at speed, I suspect a tonneau cover might help. Nowhere near as much as a fastback body would, and probably nowhere near as much as the marketing materials from the tonneau cover manufacturers claim, but I think it would be at least slightly beneficial.
Educated guess is that adding a tonneau cover would reduce the Cd by maybe 5-6%. In a gas pickup truck that probably only results in a 1-3% mileage improvement as drag is only a part of the resistance the engine has to overcome, but in an electric one, where drag is the primary source of resistance, you might just get that full 5-6% back in range when driving on the highway. It's not a lot, but it should help.
Revenant89
Revenant89
Plano, TX
2024 KIA EV6
That's just based on the model which is based on the prototypes. Also doesn't factor in the air curtains and other details. It's expected to be well below that.
Revenant89
Revenant89
Plano, TX
2024 KIA EV6
I imagine it'll be a pretty small difference with the short bed and the spoiler they added to the cab. Even on full size trucks it has a minor impact.
Slate Auto Pickup Truck Range predictions Streamlines
A tonneau cover or SUV kit may actually lower range. See the mythbusters episode on the topic for a simplified explanation.
Slate put a lot of sim time in before they even made the prototypes to optimize aero, while staying in the constraints of looking like a truck, that may make a bigger difference than on that truck mythbusters used.
Where was the 300 mile (city) range mentioned?
Revenant89
Revenant89
Plano, TX
2024 KIA EV6
Thought I'd add other predictions..
I predict 3.2mi/kwh city, 2.8mi/kwh highway. I'm basing this on 1: vibes, 2: numbers from other boxy EVs, and 3: the fact that nothing from the shape to motor/inverter is optimized for efficiency
Range
(mi)
Battery Size
(kWh usable)
Efficiency
(mi/kWh)
Highway​
140​
50​
2.80​
City​
160​
50​
3.20​
Highway​
220​
80​
2.75​
City​
252​
80​
3.15​
Slate is going to be worse than 3.8 mi/kWh. I'd guess a 5 - 10% reduction, so somewhere around 3.5 mi/kWh. That still indicates that Slate's original estimates are (understandably) conservative, but not by the suggested 33%.
Range
(mi)
Battery Size
(kWh usable)
Efficiency
(mi/kWh)
Highway​
150​
50​
3.00​
City​
175​
50​
3.50​
Highway​
236​
80​
2.95​
City​
276​
80​
3.45​
Slate's figures estimate 2.85 mi/kWh, yes? If they are off by 10%, then the truck will get 3.13 mi/kWh. Meanwhile ABRP uses a reference consumption of 245 Wh/mi (or 4.08 mi/kWh) for the Slate truck...
Humm...
Revenant89
Revenant89
Plano, TX
2024 KIA EV6
Humm...
Based on the total kWh they've given for the battery, yes. I'm assuming 3.00 mi/kWh based on a 5% unusable reserve.
