Actively considering cancelling reservation.
That tow test they did in Arizona wasn't for a commercial, it was part of the SAE standard for tow ratings. The trailer was filled with weighed sandbags to exactly meet the rating they were going for, and there are several tests they have to do. An acceleration test, the drive up that specific grade while the ambient temp is over 104F with the AC on max, and others. The standard has something like 27 pages.
At 45 MPH and 104F degrees it wasn't very strenuous compared to what will happen in the real world.
FWiW, Phoenix, AZ has a lot of days with temperatures at or above 110°F every year.
Maybe the tow rating is limited by the powertrain,'s capability.
That part of the test is a 7% grade, average 5% and a 11.4 mile drive gaining 3020 feet. How does that compare to other real world hot weather grades? In phoenix sure it's hotter, but it's also flat.
I looked up the grade in my area which is considered challenging for trucks, and it's a sustained 6% for 5 miles, but that's mostly a problem for downhill travel with truck brakes failing.
SAE J2807 Tests
TestSRWDRW
Davis Dam>=40 mph>= 35 mph
Go 5 meters from stop on 12% grade, 5 times in a row<= 5 minutes<= 5 minutes
Hold full rig with just parking brake12% grade12% grade
0 - 30 mph(level ground)<-= 12 sec<= 14 sec
0 - 60 mph(level ground)<= 30 sec<= 35 sec
40 -60 mph (level ground): passing test<= 18 sec<= 21 sec
20 mph to stop with trailer brakes active, staying in 11.5 feet lane, trailer lighter than tow vehicle<= 35 ft<= 35 ft
20 mph to stop with trailer brakes active, staying in 11.5 feet lane, trailer heavier than tow vehicle<= 45 ft<= 45 ft
20 mph to stop without trailer brakes, staying in 11.5 feet lane, trailer lighter than tow vehicle<= 80 ft<= 80 ft
understeer test: increases from 0.1 g to 0.3 g n 300 ft circlepasspass
sway test, 62 mph>= 1.0 damping ratio>=1.0 damping ratio
I think it's not just the powertrain that they are setting the 1000 lb limit by. They knew from the start about things like the range issues towing with the Lightning, and that they would be even worse with a relatively lightweight and low range Slate with any larger load, especially with any significant cross section to the wind, so they set 1k as the target and engineered for it. So the powertrain, frame, everything may all be limits if you were to try to increase the towing capability safely.
The other possibility is that if the truck is mechanically capable of towing more, the range may be so reduced that it becomes useless.
York, Pa
I have been very excited for this truck since I first learned about it. My reservation was on day 3 and I drove an hour to see a prototype. But I have been very seriously thinking about not converting to an actual order.
The brain math goes like this...
$2400 to eventually put a new battery in my '17 Fusion Hybrid(doesn't currently need one). Car is paid off and has zero mechanical issues. 42+mpg. Refurb batteries have a 2 year warranty but last much longer.
$25,000+, +options for the Slate.
- I am not rich. This would be my first new vehicle ever and the payment is not insignificant to me.
- New vehicle from a new company is going to have "new" issues. I have never bought year 1-2 of a new model.
- Repair Pal shops are everywhere but none are Slate certified. Mech or HV Electrical. You can't even look for Slate mechanics yet. Is there a timeline?
- No heat pumps initially. This is a terrible idea in Seattle. I don't want to buy the bigger battery just to run the heater 8 months out of the year. Very disappointed when I learned this.
- Insurance is still a ?. My insurance company doesn't even know Slate exists and cant give a quote. Do I want to lay down cash for a Slate without knowing how much the thing is to insure?
This is silly to toss in here but I was pretty turned off by the CEO AMA thing. I was hoping/expecting serious answers to questions from serious buyers. Nope. We got a Monte Python skit cold reading softball yes/no questions we already knew and some vague "good" answers. Almost no new info other than they are still on schedule.
Anyways. Have not cancelled yet and won't at least until whenever they convert to orders. Just putting my thoughts out there. I would still love to get one eventually but might wait a couple years. Anyone else having this dilemma?
Actually, you are in a really good place. The Fusion will likely remain reliable. I see the early Ford hybrids with high miles and few issues. So just drive it and see where takes you by the time the Slate rolls late next year. Wait even longer to see how it's doing in real world. The reservation is just $50 and refundable. Might even be new options by then.
renostever
Steve
Kansas
2019 Wrangler
Trust me on this. Once you have a pickup truck in your personal fleet of automobiles, you'll never want to be without one for the rest of your driving life.
I am a Slate fan but the pickup aspect is less compelling to me. I have owned a couple over the years but prefer my Jeep + utility trailer combo for hauling. Much easier to load and unload. I picked up 6 (4 x 8) sheets of 3/4” plywood last week and never had to lift them. I slid them on a dolly at the lumberyard, slid them onto the trailer, and cut them at home with my track saw while they were still on the trailer.
That’s what I’m living now. Just 10 minutes of inconvenience to hitch up and unhitch and store each time.
The 1,000lb towing limit sounds is definitely going to turn some people off, I know of someone that specifically was looking for something with a towing cap of 1,500lb so they could pull an A-frame (1,200lb) camper trailer. I always though the bare minimum benchmark for most vehicles was 1,500lb. Curiously, my Geo's owners manual has an interesting line at the very end:
Slate Auto Pickup Truck Actively considering cancelling reservation. 1767665270071-6
Looked up my Fit and:
Slate Auto Pickup Truck Actively considering cancelling reservation. 1767665430775-qf
But the Australian Fit(Jazz) brochure gives the following below. 450kg is almost 1000lb. So the Slate's pretty much on par with a standard car I suppose.
Slate Auto Pickup Truck Actively considering cancelling reservation. 1767665490452-ba
The problem with comparing to tow specs of older cars is it wasn't standardized at all until 2008, and until it went into full effect manufacturers could say anything they thought wouldn't get them sued or cause damage they would have to cover under warrantee. So sure, they could say you could tow a certain load, but try to go up a grade, better turn off the AC and downshift, and crawl up the grade with everyone honking at you, and you might end up stuck on the shoulder waiting on the engine to cool down.
stEVe
steve
Pacific Northwest
Volvo XC40 BMWi3
R-E-L-A-X. The Q&A wasn’t what I expected either. But let’s not pretend that’s the product. This company is clearly building something different, just look at what they’re putting on the road. That concept is why you happily dropped $50 to get on the list.
The real decision will be made the same way it always is with vehicles: What’s the total cost once you check the boxes you actually want? SUV package? Lift kit? All-terrain tires? What’s the out-the-door number?
That’s decision day. Not today, because the CEO was a little too casual about a front bench seat.
Basenji703
Virginia Beach, VA
2021 Accord Hybrid, 2007 Honda Odessy
When I heard that one, my thought was that most would probably set up a rack and drive with the board on top of the truck.
I like to take two boards with me and leave one locked in the vehicle. If I just bring one, it is sometimes the wrong one. :)
Memphis
Sorry to say, but I'm much closer to cancelling now. I've not been happy with SLATE hearing about the lack of some things like the blind spot warning feature and powered mirrors.
Today I started the process to purchase a Hyundai Ioniq 6 sedan. It's a Hyundai-certified used '24 Loaded Limited trim with less than 7,000 miles on it. Still has nearly 5 years left on the bumper-to-bumper warranty and nearly 9 left on the 10 year powertrain warranty. It's loaded with all kinds of safety tech, is AWD, screaming fast, and has most of the extra options. Long range too and has super-fast DC charging though we'll never use level-3.
I know it's not a truck and it sure isn't simple, but my interest in the SLATE wasn't for the truck feature, it was for a decent low-cost EV for use around town for just my wife and I do to stuff. so in that regard it's still an apples-to-apples choice based on what I am paying for it. This Ioniq isn't brand new but it depreciated so much the gently used and warrantied example I found is under $28K.. just about half of it's original $55K MSRP. Still a bit more than the original $20K that attracted me to the SLATE, but that ship has sailed.
I'll wait until I put it through its paces before I completely bale on the SLATE and my very early reservation, but right now and in the next year or so the EV market is going to get flooded with lease returns, and there are going to be more low-milage options out there. Slate is going to have to be at the top of their game to compete! I wish them well.
Getting very close to share your sentiment. Slate says it is trying to compete with used cars, and, if the "truck" form factor isn't important to you, it does not!
Absolutely screaming deals on EVs right now. Every used EV is pretty much 40-50% off MSRP even with low low miles. The Slate will appeal to many, but if my choice is a bare bones, no radio truck with 0 miles from an untested and unproven manufacture, and a 15k mile EV with speakers, adaptive cruise, real support... The choice is obvious, dollar for dollar.
Entertaining that those on the Cancel Spectrum feel they have to come here and post their rationale. Doubtful you’ll be missed. Not a big deal, cancel and help someone who really wants a Slate move up the cue and enjoy your choice. We intend to and I seriously doubt we will wonder about those that changed their minds.
