- Joined
- Jan 11, 2026
- Threads
- 1
- Messages
- 784
- Reaction score
- 1,000
- Location
- Northeast Ohio
- Vehicles
- CJ-7
Actually there’s more to it than that. Dr. Dahn seems to focus more on state of charge (expressed as SOC for us who are still learning abbreviations) than charge rate. His takeaway for lithium nickel manganese cobalt oxides is the lower the SOC, the better.Thanks for posting these informative videos. It’s very helpful to understand the chemistry behind EV charging practices. In practical terms, the key takeaways are:
Finally, in an interview Musk explained why it takes so long to charge from 80% to 100%. Sometimes as long as charging from 20 to 80%. His answer (we can ALL relate to this):
- performing 2 separate charge sessions over a couple of days, each consuming 30 kWh each is way better than a single charge consuming 60 kWh.
- Even better, performing 3 separate charge sessions over a few days, each consuming 20 kWh each is way better than a single charge consuming 60 kWh.
- Don’t store your EV at a high SOC % in hot climates
You need to equate the charged particles (ions) to a car trying finding a space in a crowded parking lot. As the parking lot fills up, you need to drive around the lot more times to find an open space, often passing the same areas multiple times. You keep driving around hoping someone pulled out, and then you get there and another car (ion) beat you to it! 🙁
His presentation focuses on the NMC chemistry.
