Range vs Wheels size
SteveD62
Steve
Honda
I was wondering if anyone knows of the difference in the range you can expect going from 17 to 20?
My understanding of wheel assembly and range is:
1. Reduce total/overall weight
2. Skinnier is usually better (for range)
3. Maintain air pressure or even raise air pressure, within your comfort level.
fxrdr31
Andrew
Wayne, MI, United States
Ford F150
Smaller rims typically mean less weight and smaller tires as well which means even less weight. Setting your tire pressure to the max psi will increase range/fuel economy on any vehicle but will increase ride harshness. Project Farm did a video on a gas hog of a vehicle that is a good watch but far from the complete
It seems there are 2 possible tire diameters offered. A 29.5" diameter and a 31.5" diameter. There is an optional 31.5" tire for the standard 17" wheel. It looks like 20"wheels have a 31.5" tire. Specs on the Kenda Vezda UHP A/S2 tires are missing. A larger rim does not always mean a larger diameter tire.
FloppaEnjoyer8067
minnesota
2016 bmw 428
It will also wear your tires unevenly, causing you to burn up your tires faster. Your vehicle handling will also be significantly worse as it vastly changes the tires mechanical properties.
AeroWolf
Tidewater Va
GMC Sierra
You can use some simple physic to get an idea of range impact. I admit to using CoPilot to help me whip this up.
Slate Auto Pickup Truck Range vs Wheels size 1782683285631-qc
It is very simplistic.
FloppaEnjoyer8067
minnesota
2016 bmw 428
I don’t think wheel diameter will have a great effect on range. Motors have a pretty flat efficiency curve, so it shouldn’t make a big difference.
Bearing friction is also fairly non linear, so it will be hard to predict.
I’d put money on tire selection having the greatest impact on range, but due to the compound and tread, not the diameter.
Theoretical Motor dyno curve for reference.
https://external-content.duckduckgo...b6360097e5c9fe73c51fe33d096900d85c26718e5cb48
Oddballhero
Here
ICE car
This being the case, putting smaller wheels should do better for range. 16s, maybe?
A 17 inch or a 20 inch wheel with a 31.5 inch tire has a diameter if 31.5 inches.
A 31.5" tire has approximately 650 revs per mile. A 29.5" tire has approximately 700 revs per mile. So a taller tire is like a higher gear ratio. A bigger tire spins slower.
From what I've read, different tires can have a huge effect on electric vehicles. And the effect might not be what you want.
AeroWolf
Tidewater Va
GMC Sierra
Part of the issue is you are increasing the energy bound in the heavier larger diameter wheels. This makes more city stop and go less efficient for EVs, But you could get a better highway efficient where the increase in overall wheel radius may help against, presuming that is not defeated by the added mass of larger wheels.
Shrink36s
'18 Equinox
I would like a wheel upgrade to something in that 17x8 size that is focused on maximizing range. Something lighter than the steelies and aerodynamic. I’m interested in increasing range without reducing utility.
Not a lot out there that I’d pick rinse searching around a bit.
AeroWolf
Tidewater Va
GMC Sierra
Forget about any wheel mounted aero improvements. Unless you are putting on fender mounted wheel covers. Think Aptera
