- First Name
- Kevin
- Joined
- Mar 29, 2026
- Threads
- 10
- Messages
- 426
- Reaction score
- 969
- Location
- Grand Rapids, MI
- Vehicles
- Toyota Sequoia, Toyota Highlander, Ford Escape, (previously) Ford Ranger
Changing the gear ratio has a slight efficiency impact - here's a chart from JJE (Slate's motor manufacturer) for a very similar motor:Different tire diameters don't, by themselves, change the number of watt/hours it takes to dive a given distance. It just changes he gear ratio. If the motor turns more slowly at a given speed, it will take more amps, fewer volts. If it turns faster, more volts, fewer amps. Volts times amps = watts. And (kilo)watt/hours are what the battery stores. Changing the tire size can have an aerodynamic effect, but I have to think that Slate's engineers have optimized the wheel and tire size for range.
(Source press release here. That 300 kW motor with locker might be a nice crate motor upgrade for a high-performance Slate!)
The torque required to move the vehicle at various speeds on level ground will be a parabola through that efficiency map going up and to the right, changing wheel size will shift that parabola sideways. There's a particular gear ratio where the parabola goes through the max efficiency star in the center, I expect that Slate will have chosen the final drive ratio such that this efficiency is achieved with the standard tires to maximize range.
Larger tires will shift the parabola to the left, slightly reducing efficiency. But that's merely changing the efficiency from 95.2 to maybe 94.5, relatively insignificant.
