I think for many people, a regular bed topper would be a cheaper & probably better option than the cargo kit (read: not SUV kit)
That aside, the SUV kit has never really made sense to me. It's fun, and I love seeing another 2 door SUV on the market (looking at you, 2 door Bronco!)
The Truck only makes sense to me as a truck. If you have to start adding on all the extras, the math doesn't math for me anymore. Give me a double DIN fascia and the in-dash speakers, and I'm set.
As far as DIY-ing, I'm all in for it all. I would rather install the accessories myself than have a RepairPal center do it. For warranty work, unless Slate is paying me for standard dealer technician rates (which they won't) then I'm not doing it. If Slate can't figure out where to have it repaired near me, then I'll Lemon Law it and move on. This probably sounds like I'm being a hardass, but Slate Auto is a company, and if their model doesn't make sense, it doesn't make sense. I don't have to baby them just because they're a new quirky startup.
TomFrank
Tom
Radnor, PA
Subaru Crosstrek 5M
The difference, at least for me, would be that a bed topper limits access to the bed from the topper window & tailgate, while the non-SUV cargo kit sounds like there's access to the bed from the cab. At the Philly Zoo event I asked about access to the rear footwell area in the truck configuration and was told the only access was from the bed by removing the panel that is the front of the bed floor. I'd consider a tonneau instead if there was a way to access the rear footwell area from the cab.
atreis
In nearly every post from @atreis he mentions his need to flat-tow a vehicle behind is RV. He has stated he hopes Slate addresses his need to flat-tow. You can read on most car forums that flat-towing modern vehicles that have computer-controlled drivetrains is difficult. You can read numerous posts on the Bronco forums where owners follow the instructions to set their Bronco in flat-tow mode only to find they have burned out the automatic transmission because the computer did not set the automatic into neutral or the automatic for some reason switched out of flat-tow mode.
Making an EV flat-towable is not a simple task because most EV have some level of regenerative braking. Even electric golf carts have a switch to electrically disconnect the electric motor. I suggested a vehicle that has manual-shifting driveline transmissions that no computer is required to operate their gear selection modes. I didn't say a refurbed Wrangler is the same as a new EV, I suggested a fully-manual Wrangler (i.e. physical-lever-shifted transmission and transfer case) to eliminate concerns with flat-towing a vehicle behind an RV.
Slate has said they're looking to make it flat-towable. It's not just idle speculation. Rivian said the same though, and then backed off that when they released the R1T. Thus my skepticism. That said, if the Slate is, I'll buy one. If it isn't, then I have no interest. I have an EV I'm happy with as a daily driver, and currently flat tow a Ford Fiesta. I'd much rather have an EV that's flat-towable though so that I could have just one car where I currently have two and will buy the first that becomes available and fits within my towing weight limit. (And yes, as I've also said, it's a niche thing. But it's MY niche thing. :) )
Flat Tow support for Slate truck in the works [confirmed] | Slate Truck (EV Pickup & SUV) News, Forum, Owners, Community, Discussions
Agreed, prefer the non seat/rollbar option and hope keeping the lower midgate is an option (help keep my dogs in the back) Locally, apu with bed topper is quite common, suspect Slate sees that as an option. If I can’t get the SUV topper without seat& roller ball for reasonable $$, then waiting for a 3rd party option will be my option.
The fact of the matter is, if someone is shopping for an EV SUV to get them to and from places, the Equinox EV will beat out the Slate more often than not.
Not for me. I wouldn't buy a Chevrolet in general, and an Equinox in particular.
For me two doors is a feature, not a bug. I also like the ability to easily convert to an Open Air configuration. Maybe having the ability to re-wrap every once in a while tickles someone's fancy.
Maybe someone wants to have something that's "different".
The list of reasons someone might prefer a Slate (or any other SUV) is long and might not make sense to you or me.
Without a doubt some people buy an SUV as a Transportation Appliance, but most people choose which vehicle to buy for emotional and less-practical reasons.
If you remove the window from the rear of the cab and install a "regular bed topper" that seals to the cab you achieve what I'm looking for.
This.
It would be nice if they at least added an accessory option to access that area from the cab in truck configuration. It would add more storage, and you could put things like small tool bags there, out of sight, where no one would think to look.
Whitesands
Alamogordo, NM
2011 Dodge Durango
I mean.... pointing out flat towing support is the definition of picking and choosing arguments. Useful for some, but a vast vast majority of Americans never flat tow a car.
There are 100% use cases where the Slate is better for a consumer, but I would argue that those are the exception, not the norm.
Im going to point out that Flat-towing support can help others who never tow it behind an RV. Since Slate is rear-wheel drive, Towing it requires lifting that axle. If the motor can be disengaged then tow trucks can lift the steering axle instead. Same with car dollies.
"When in doubt, just flat-bed it."
Perhaps I’m in the minority, but a deciding factor in my car purchases is not how easy it is to tow
Whitesands
Alamogordo, NM
2011 Dodge Durango
It's not a deciding factor for me either, but it is a feature that could help others. I'll buy the slate even if it didn't have it.
200 so far qualified, specifically for the high voltage part. probably at least a year out from anyone even having a truck to take in for service.
Those 200 are probably shops that already have training and certification to work on HV systems for other EVs. when I searched for shops that could do EV powertrain service, the number shown locally did drop. Most likely any shop in the network will be able to do most other work, like installing accessories you don't want to do yourself.
The number of shops servicing EVs is naturally going to grow, even if slate wasn't being built, just because of the increasing number of EVs on the road, and the increasing number that are getting older, and likely to need non-warrantee service.
KBB on Slate’s Repair Network
According to this report, out of the 4000 listed Repair Pal shops, only 200 are trained or qualified to work on Slate trucks. Apparently an inherent risk to taking an early delivery in 2026.
The 200 is ones authorized to work on EV high voltage systems. More of the 4000 will be able to do basic car stuff
