Status
Not open for further replies.
Parts of the app will probably be rather simple, for example with navigation it will probably just be a wrapper for an already available nav app.
On the fob function, that's part of the problem with asking for details that early even though messaging an agent. As far as we know, the truck itself will have no wireless connection at all besides the fob, no wifi, no cellular, no bluetooth, but there is that occasional conflicting agent statement like "The Slate App will allow you to remotely activate climate control, lock/unlock doors, and more."
That would specifically require one or more of those connections. An add on connection card might be possible, but it hasn't even been hinted at.
I would like to be able to turn on the climate control remotely. When leaving home, the fob range would work, but when leaving a store or work, you need more range.
With the manual knobs, it would have to be either just power on the climate control with the settings you left it on, or those knobs could be rotary encoders.
Getting kinda picky here, but there's one exception:
Steering Wheel Bluetooth Controls
Slate Auto Pickup Truck Special Q&A for Reservation Holders w/ Slate Auto CEO Steering_Wheel_Bluetooth_Controls
This would be my first EV, and probably the first EV interest for a lot of people. I have been watching and reading all I could on Lucid, but they are in the $80,000 to $250,000 price range. I had no interest in Tesla or Rivian or the others. I think there will be a lot of questions not directly related to Slate, but about EVs in general. How would the Slate navigation part of the Slate app be different than using the Waze app, which I already have? Would the Slate app show things like miles remaining, battery condition and use, or is that part of the built in speedometer screen? How do you set it to charge to only 80%, or all the way to 100% for a long trip, or is that a setting on your charger? I have a lot of questions, and I have at least a year to read up on a lot of it dealing with charging and other general EV information. I've already learned a lot from this forum.
My reading of that accessory is that it has nothing to do with the truck at all. It's just a generic volume & play/pause remote control that's made to fit in the steering wheel. Something similar to this thing from JBL.
Hopefully Slate comes up with a better solution than using a 3v battery in the steering wheel remote control.
Yes, definitely. It's similar to a remote shutter for cellphone cameras that are for removing camera shake or taking selfies.
Slate Auto Pickup Truck Special Q&A for Reservation Holders w/ Slate Auto CEO BT_Remote_Shutter
I think all the shutter gizmo does is connect as a keyboard and send a "Volume Up" keyboard signal when you push the button.
The media controls accessory does the same (connects as a BT keyboard), except it has multiple buttons for sending play, pause, next, and previous.
Understood and I'm hopeful too. But the SUV kit requires removal of the back wall of the cab which would provide some rollover protection in the pickup configuration. I fear the rollbar may be needed due to that as much as it is needed to protect seated back passengers.
Slate has made it clear that the SUV kit contains the topper, rear seats, and roll bar containing air bags. The assembly of these components follows a strict sequence / procedure utilizing mistake proofing, or Poka-Yoke. Meaning that error codes will be displayed and the truck might even become disabled if you purposely omit the rollbar or go out of sequence which could compromise safety. Please take note, there is a huge liability issue if the air bag harness is not properly installed; and you should expect an electrical interlock will lockout the vehicle from normal operation.
Regarding the cargo kit, hopefully it will omit the seats, roll bar and airbags but it will follow its own installation procedure which differs from the suv kit.
Kia Forte Koup
My understanding is that when the rear window and bottom panel is removed, the roll bar is needed for structural integrity. Presumably, the cargo kit would not entail removing that bottom panel...
The cargo kit may not require the removal of the back wall of the pickup cab, possibly only the back window which would be used on the back of the cargo kit.
Kia Forte Koup
I think you are thinking too advanced. My 2015 Kia can lock/unlock doors with the fob, no wifi needed. Having the fob turn the HVAC on/off from a button also doesn't require wifi. That would give you the ability to turn on the climate control remotely, but not change the temperature.
That doesn't solve your range issue though...
Kia Forte Koup
Also navigation and media controls when driving.
Ideally the app will just do a small number of necessary things and do them well.
Are navigation and media controls necessary? It depends on who you ask, I suppose.
Here's hoping they don't attempt to "monetize" with the app, because that would be a huge turn-off to a lot of people.
I remember seeing a closeup of the "app" during the post launch press event on some YouTube channel. It was clearly just a bunch of images in a slide show.
"So, there's a cargo kit that you can get instead of going with the SUV kit. And that's basically or essentially the SUV kit without seats."
-- Senior Secret Agent Aphrodite (source)
Considerable lack of detail there. Basically or essentially there's plenty of room for interpretation.
It was #2 in her list of Top Five Questions people ask. Maybe some of those people are looking for a Canine Carrier Combo like many of us are.
Agreed IF installing the rear seat. Rear seat requires the rollbar and airbags. If no rear seat, no need for airbags. If no rear seat, no airbags will the rollbar be required, we don’t know. Error codes would be dependent on presence of the rear seat. Slate has stated you can remove the rear seat, so would assume no error code. I’d say doubtful you can properly install a rear seat without the airbags and/or rollbar.
I bet that is their intention is HVAC on/off is from remote range versus a Tesla which I can turn on the HVAC on from say 2 train stops away from where my car is parked so it is cooled or heated when I arrive. I think most ICEV that have remote start are doing it from within the range of the remote fob. Incidentally, Nissan was using satellite for the same 'long distance' functionality on the Nissan Leaf. This worked regardless of whether you had a Sirius/XM subscription or not, though it doesn't work very well.(I sold my 2022 Nissan Leaf this past week, have a 2026 Tesla Model Y coming on 12/22)
Have we even gotten any confirmation that you will be able to turn the AC on and off remotely at all, or was that one of the "we'll look into this" kind of things?
That might need to be a question asked.
"Will Slate have remote control of the climate controls, to warm it up on icy mornings, and cool it on hot summer days, before you get in the truck? And if so, what will the range be, and will mode and setting be remotely adjustable?"
The adjustable part depends on how the system is built. It is possible that it's electronically controlled, like the steering, and the knobs would be rotary encoders.
Status
