Malort
Chicagoland
2023 Maverick, 52 Chrysler, 39 Ford
So I asked ChatGTP to style a Slate to resemble my old 84 Mazda SE5 truck. It screwed up some of the Slate details like the wheel arch/opening, but all in all a pretty good rendering. I like it..........
Slate Auto Pickup Truck Share your Slate build configuration images! SE5
Slate Auto Pickup Truck Share your Slate build configuration images! Slat
Slate Auto Pickup Truck Share your Slate build configuration images! SlateSE5
Garbone
Curious if it will get stuck on the beach.
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2025-05-23 8.20.12 PM
I think it will do better than most people think. With the battery located where it is, the weight between front and rear will be pretty close to 50/50. I have a RWD Tesla Model 3. I went to look at a Gravely tractor and the seller lived on top of a mountain in north Georgia. I drove my Model 3 right up this steep loose gravel driveway no problem. The following day I rented an F-150 4WD and returned to buy the tractor. Going up the same driveway I started spinning and had to shift it in to 4WD to make it to the top.
I would deflate the tires to less than 20 psi to tackle sand though.
It dawned on me that since the panels are all 'individual' and designed to be wrapped independently, that you could option different colors on whatever panels you wanted.
Slate offers white lower/upper white body wrap, but I wanted to see what it would look like in a two-tone. I wish the Slate builder let you pick specific HEX values for the colors, would have made trying to use that clunky little color wheel a bit easier.
I had to stitch two screenshots together as you can't do a two-tone wrap like this yet, I'm tempted to do this if I didn't go the full deep-emerald-green route:
Slate Auto Pickup Truck Share your Slate build configuration images! Slate3
Ideally would like an Aston Martin winchester blue top with a darker lower:
Slate Auto Pickup Truck Share your Slate build configuration images! 1750674098934-ga
Yes, I believe it’s because a new thread was introduced after Slate updated their maker with the unique build code:
What’s your Slate Build Code
It would be great if the admins could merge both threads so we can see the progress of everyone’s work over the last year, all in one place.
TRexius
Tomas
Raleigh, North Carolina, USA
Jeep Wrangler 2 door
I've been brainstorming modifying some models i love the all but most probable ill get the red on white due to save as much range as possible. The only thing the shares all the models is the interior since i love brown interior. UPDATE: I MEAN THE TIRES PEOPLE offroad tires even if they look good it hurts range.
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 154754
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 154806
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 154815
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 154646
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 154829
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 154703
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 170042
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 170420
Slate Auto Pickup Truck Share your Slate build configuration images! Screenshot 2026-05-15 170413
I've been brainstorming modifying some models i love the all but most probable I’ll get the red on white due to save as much range as possible.
How does choice of wrap preserve range?
