12V Accessory Bus Bar / AUX Switch Array
One of the things I think would greatly benefit the Slate is a hot 12V bus bar line where owners can wire up their own accessories. If these are going to be fleet vehicles it would benefit them to let operators easily install dashcams, CB radios, etc. The Broncos have a set of AUX switches on the roof for such addons, and even my old '89 LTD has a ground BUS bar for adding accessories as it shares the wiring harness with the Police / Taxi package.
Either that or some extra unused 15A interior circuits available on the fuse panel. I know I could use at least two of them if I were to standardize the Slate with the rest of my fleet. I'd hate to use fuse taps on a brand new car!
Edit: Here's what the ground bus in my LTD looks like:
Slate Auto Pickup Truck 12V Accessory Bus Bar / AUX Switch Array 1746840681874-b3
crownmountain
Dave
Durham NC
I would happily settle for a USB-C hub of a five ports
G19Tony
Tony
Las Vegas
2025 Ford Maverick XLT, 1994 Ford F150
The maverick too
I’m thinking about that for my Maverick. I add a Fuzeblock to my motorcycles. Don’t see a reason you couldn’t do that in the Maverick. Plenty of room under the hood.
We know the Slate will have step-down voltage power for at least one device and based on what the CEO said in her recent interview, for a double din head unit as well. It makes sense that having a 12V fuse block and negative ground bus bar would be included...most likely located behind the dash panels. Those fuse block circuits better be at least 15A. The first thing I would do is install a 12V cigarette plug outlet for a USB combo (A/C) charge plug so other devices can be charged up front.
Sparkie
Sparkie
Massachusetts
Bronco
I agree.
If the Slate Auto philosophy of owner customizable stays true, then an electrical aux panel pre-wired to the fuse box is something we should expect. Then Slate could have a whole bunch of accessories they could also sell for owner installation.
Going through the designer portion of the website again after seeing the white roof add-on and found there's now an option for AUX buttons over the HVAC panel:
Slate Auto Pickup Truck 12V Accessory Bus Bar / AUX Switch Array 1747671656866-hu
Looks like a quick add-on to the website as it doesn't appear to even have a texture. Still a good idea if it features spade connectors in the back or some other method of quick install for hot and ground. I would mainly be using it for applications that don't require a huge amount of power but would need to be powered by vehicle turning 'off' and 'on,' (I don't want to have to turn on my power dimmer mirror and dashcam EVERY time I use the truck) so I am curious what the planned behavior is for these. The fact that they talk about lights makes me think it should be designed to handle some amperage.
Sparkie
Sparkie
Massachusetts
Bronco
Nice catch on their website. I didn't see it earlier.
That looks like a very last minute concept 3D model.
