Bigger may not be better when it comes to the battery.
I wouldn't be worried about charging to 100% battery nominal voltage either, usually ~4.2V. I've used and abused Lipo batteries on my RC planes for ages now and to my surprise a very cheap set of Lipos that I've had for almost 10 years still charges and discharges well and powers my fun little parkflier with no issues.
Even charging to 100% does not mean the cells are truly going to 100%; there's a buffer built in - my Mach E has about 7% buffer built in so even when I charge to 100%, it's less than that in reality.
No doubt there will be a hidden buffer. They'd be crazy not to do that.
The reason I wrote that state-of-charge should be kept between 20% and 80% is because I looked it up and that's what I discovered.
I just looked it up again.
Question
What kind of battery chemistry does a mustang mach e have?​
Answer
The Ford Mustang Mach-E can have either a Nickel Cobalt Manganese (NCM) or a Lithium Iron Phosphate (LFP) battery chemistry. The choice of battery depends on the model year and the specific range variant. [...]​
Question
What kind of battery chemistry will a Slate Truck a have?​
Answer
The Slate Truck will use nickel-manganese-cobalt (NMC) batteries rather than the cheaper lithium-iron-phosphate (LFP) batteries. [...]​
Question
Should an EV with nickel-manganese-cobalt (NMC) batteries be charged to full capacity and/or discharged to near-zero capacity?​
Answer
For electric vehicles (EVs) equipped with nickel-manganese-cobalt (NMC) batteries, it is generally recommended to avoid charging them to 100% capacity and discharging them to near-zero capacity to maximize battery longevity.​
Charging NMC batteries to 100% every now and then is acceptable, but they should not be left at full charge for extended periods.​
It is also advised to keep the battery state of charge (SoC) within a moderate range, typically between 20% and 80%, to prevent excessive stress on the battery.​
Discharging NMC batteries to very low levels can also be detrimental to their health. Most EVs have built-in battery management systems (BMS) that prevent the battery from being completely discharged, but it is still best to avoid letting the battery drop below 20% if possible.​
Regularly charging and discharging NMC batteries within a narrower SoC range, such as between 40% and 80%, is believed to be better for the long-term health of the battery compared to frequently discharging it to very low levels or charging it to 100%.​
In summary, for optimal battery life, it is advisable to charge NMC batteries to around 80% and avoid discharging them below 20%, unless necessary for long trips.​
As an EV n00b I can't vouch for the veracity of this. Source is Brave Search. Popup links to web sources are provided in the answers there, but those didn't transfer to here.
Question
Answer
Question
Answer
Question
Answer
I think multiple sources have confirmed that a 20-80% charge cycle is ideal for NMC.
evtruth
PlugLyf
Warsaw, IN
linktr.ee
Slate hasn't been exactly clear about the range. It says the smaller battery is "good for 150 miles". Does that mean useable range down to a 20% SOC or is 150 miles at a depleted 52.7 kWh. If the latter, that's just a 120 miles of range if one takes the battery down to 20% SOC. Keep the battery on a trip with DCFC and 20% - 80% depletion cycles is just 90 miles. And that is in temperate weather.
Pretty much every manufacturer does 100% to 0% when stating range. I would bet on that being the same for Slate.
Benjamin Nead
Ben
Bisbee, Arizona, USA
2012 Mitsubishi i-MiEV
Yes, true. It's the EPA's test cycle. Just like with gasoline vehicles, it simulates a mix of city and highway driving. And the tabulated range number is based on the availability of a full pack. The EPA numbers are always more stringent (ie: less optimistic) than the European NEDC range estimates. The most wildly inaccurate and overly-optimistic ones are the Chinese WLTP numbers. But any vehicle that's legally sold in the US is going to be tested on the EPA cycle (at least for now.)
