Roadster pickup!
denis4x4
Dennis
Durango Colorado
70 VW dune buggy, 71 VW Super Beetle Convertible, 08 Ford F-350, '20 Chrysler Pa
Asked the question and was told no. However, I've added some bracing to a couple of pickups before cutting the top off and adding a cloth top. Curious as to the frame design and material that might allow for modifications to remove the top.
Check out thread by Cody, Here’s The Engineering Behind The $20K Slate EV
If that is a link, it doesn't work for me. I tried searching that title and it says no results. Do you have a different link?
No link, search on Cody’s posts
One compromise could be taking the doors off and removing the rear window assembly. Personally, I won’t be removing the doors but could see removing the rear window assembly for more of an open air experience in warmer weather.
I'm guessing those 'couple of pickups' were all body on frame? Slate is not, which makes it a while nother can of worms.
Given that this is a unibody the pickup bed is structural to the truck. I bet reinforcing the back of the cab to the pickup bed would probably help with stiffening it for a drop top conversion. The battery pack in EVs acts as a structural member so that probably helps loads too.
Those Dakota convertibles are pretty snazzy, I'd love to see a Slate in that style!
Slate Auto Pickup Truck Roadster pickup! 1769469119463-tv
I had an S-10 converted. It was fantastic.
Part of the conversion was reinforcing the A-pillars.
Unlike a body-on-frame S-10, the Truck's cab's structure is part of the frame itself.
Slate Auto Pickup Truck Roadster pickup! Slate_Truck_Fram
Edit:
This one's not mine, but it looks like it was converted using the same kit. I removed the sun visors for a cleaner look.
Slate Auto Pickup Truck Roadster pickup! S10_Convertibl
