How do you feel about Slate's towing capacity?
How do you feel about a strictly 1k lb towing capacity for the Slate.
    85
Fair enough, I just figured it would most likely all follow the same rules considering all of it falls on the same spot on the vehicle but that is entirely my own interpretation there. It was also my understanding that tow packages, atleast ones that up towing capacity, are done by the factory and not dealerships. If dealerships do install tow packages that upgrade towing capacity, then I would imagine a kit would work but I have not found a lot of information form the NHTSA on any of it.
[Not trying to be disrespectful]. I think you are trying too hard to find fault with the idea of a DIY tow package. I understand you are interested in knowing if the FMVSS regs cover it, I don't think they do. I don't think it matters.
PJ: Perhaps I missed it, what is the planned GCWR to be on this truck?
Slate:
Hey Patrick,
Thanks for the question!
The Slate will weigh around 3,800 lbs, with 1,000 lb towing capacity and 1,400 lb payload capacity. Official GCWR and complete specs will be ready once production starts at the end of summer.
Keep an eye out for our announcement in June where we'll be sharing more technical details.
Best,
STEPHEN
SENIOR SLATE AGENT | SLATE
Hmmm. That's interesting. According to the original specs at launch, Slate listed the curb weight as 3,602 lbs. Since inception the truck has already gained ~200 pounds. However, the payload has only dropped by 33 lbs. One would expect that the payload rating would drop by a similar amount. Looks like there was some margin in the original estimates.
Yup. When I saw that it reinforced the thought that base battery will be LFP.
The June announcement will disclose not only price, but also the details on the battery. If the standard battery chemistry changes to LFP, then the 150 miles range is more credible as dally charging is now possible to 100%. And that explains the vehicle weight increase by 200 pounds!
If this turns out to be true, that's a nice piece of detective work there, Mr. PJ GaRailroader!
Slate:
Hey Patrick,
Best,
STEPHEN
Well, at least it's now "we'll know more 'once production starts at the end of summer'." :clap:
The tow package [for the Maverick includes a higher performance cooling system, transmission cooler, Class 3 hitch and a 7-pin trailer connector including a trailer brake controller.
The key to note in the above is that in order to go from 2k# to 4k#, they are not updating the frame or breaks in any way. It's all about upgrading the cooling system to keep the engine from overheating.
I'm not sure what that would mean in an EV context.
In an EV context, to satisfy passing the SAE J2807 trailering test to determine a normalized trailer towing spec (comparative within the industry) additional cooling may be necessary to keep the traction battery from overheating. Most EV share the heating/cooling system between the battery and the cabin. Because the J2807 test requires the hill climb at maximum AC cabin cooling, an EV may need additional cooling to control the heat (thermal) load across both the cabin requirements and the battery requirements. More work means more heat load to shed.
Adding an oil cooler to the EV drive unit could help in cooling the electric motor even beyond the what the battery/cabin heating/cooling system can provide.
Again, I doubt the Slate's cooling system is undersized for a towing capacity of 2,000 to 3,500 pounds. I think the 1,000-pound limit is only related to battery capacity and range limitations. But if there is a thermal consideration, adding a second row to the radiator(s), a trailer brake controller, and possibly an oil cooler for the drive unit, would add just a few pounds to the overall chassis weight with zero penalty to daily range. Additional software (if required) would not weigh much either...
JoeBlow-Kokomo
Michael
Fort Wayne, IN
The Ford Maverick base configuration (FWD) has a tow rating of 2,000 pounds. The Maverick AWD Hybrid can be upgraded from 2,000 pounds to 4,000 pounds with Ford's $745 tow package. The tow package includes a higher performance cooling system, transmission cooler, Class 3 hitch and a 7-pin trailer connector including a trailer brake controller. With that configuration, the AWD Hybrid 4,000 pounds tow package has a curb weight of about 3,780 pounds. So the Maverick can tow over its curb weight.
Reviewing the Munro chassis video, I saw no components that were too lightweight to support a 2,500 or even 3,500 tow rating.
Slate's position on the 1,000 pound tow rating wasn't very definitive on whether the rating was thermally limited (they sort of hinted) or range limited (they sort of hinted). Adding less than a 100 pounds of upgraded cooling system hardware (included in a towing kit) is not going to affect the efficiency rating of the Slate Truck, which is mostly drag-limited due to the general shape of pickup trucks.
The question whether Slate can change the GVWR after sale (assuming the kit is ordered at the time of sale) is unknown and probably a gray area in the FMVSS regs. Considering no other manufacturers sell a reconfigurable vehicle that changes from a 2-seat pickup truck to a 5-seat SUV, the FMVSS probably doesn't directly address safety standards for such a vehicle. Obviously Slate has found the regulations do not prohibit owner-installed equipment to convert the pickup to an SUV. I'd bet the FMVSS regs don't prohibit an owner-installed DIY tow kit either.
Munro on the Ford? Or have they looked at the Slate? Towing ratings gotta be tricky. Towing in hilly/mountain places is a whole nuther world from towing in the flat midwest where I am.
Uhaul has aluminum trailers in a few sizes. Much lighter, but still not a lot of load left.
This^
Thank you. This is exactly why I brought up the subject of the Slate's towing spec (a few months ago). Uhaul's lightest cargo (box) trailer is 850 pounds. Its lightest utility (open) trailer is 630 pounds. For my case their motorcycle trailer weighs 870 pounds. Both of my street bikes weigh nearly 800 pounds, so it exceeds the Slate's capacity by nearly 700 pounds. I have had on occasion a need to rent a local motorcycle trailer to get one of my bikes to a shop for tires (in December). My H3T handles such a task without even noticing there is a trailer out back. I'm pretty sure the local Uhaul dealer would not hook up a 1,000 pound trailer to a Slate spec'd at 1,000 pounds max trailer weight.
On the Slate. There is a Munro video on the Slate that deep dives into the chassis. It's up on a lift and they go through the entire underside with the engineers who designed it.
Why not just load the 800 pound street bike directly in the bed and eliminate the need for the trailer altogether?
I haven't been paying close attention, but have they said a different load capacity with the small or large battery? I think they were saying the larger battery is something like 300+ pounds heavier.
BobSentMe
Casey
Detroit-ish
Ford Escape
From what I've seen, pretty much all rental equipment ends up being over the 1k limit.
I think you misunderstand my use of the trailer. It'll be for hauling drywall / wood / cabinets / etc. I have a house that needs to be remodelled after my kids move out, not rebuilt from the ground up.
Your inquiry should be addressed at the June announcement. 🙂. Hopefully.
