Wrap or no wrap?
Wrap or no wrap?
    52
Need to get a wrap with the rust above rear wheels like most pickups get eventually. Funny for a plastic body. Not all old ones rust though. Here is my 1996 F150 with 180,000+ miles.
Slate Auto Pickup Truck Wrap or no wrap? IMG_4626
Slate Auto Pickup Truck Wrap or no wrap? IMG_4637
R56, CX3, SA, C1500, E150
I would like to wrap the roof, hood and upper panels like the analog and grit style, but without the fancy black patterns. Can anyone tell which color reflects the most sun? My previous search indicates glossy white or metallic silver. It's hard to tell from the color options which one is the most white. 😂 I would like the roof white to keep the inside cooler, the rest is for a streamlined look.
AeroWolf
Tidewater Va
GMC Sierra
You want highest technology pigmentation white your budget allows.. Probably a high gloss or satin white.
Though you may find tinting your windows with IR reflective coatings and window shades more effective at keeping the interior cooler.
Thanks! I need all the help there is, mainly for my dogs and desert camping.
I am getting some vinyl rolls on Amazon to practice. There are some blemishes on the hood of my daily driver that I can cover with a strip down the middle. If it's something that I can handle, I won't need wrap from factory. 🙂
Have you consulted with your local wrap shop? They might have some insight into what would achieve your goals.
NH425
New Hampshire
Wrangler
No wrap for me ..... at least not right away. That Cherrybomb starter kit has caught my eye tho. It'll depend on the truck itself. I do have such a soft spot for base vehicles it takes a while before the first mod arrives.
I do have a couple of partial wrap builds in the maker, but will start out with Blank Slate. First reason is a matter of logistics. Wherever I get delivery, my 1st priority is getting my Slate to port in San Diego. Hopping that can be arranged as part of purchase so I can avoid having to do in person.
all future accessories will be shipped for DIY.
Unless there's an incentive to order the wrap with the truck, I'll probably skip the wrap at first and just go blank-slate. But it'll most likely be an early DIY project a few months later.
pdxmotorhead
Dave
Portland OR
I wonder if bedliner would adhere to the plastic, Guy could use one of the newerr thin glossy versions and it would just have some texture.. Plenty of jeeps have done it, And its easy to touch up..
pdxmotorhead
Dave
Portland OR
I've always found light blue stays the coolest of the cars I've owned, Maybe a old school sky blue upper and white sides with more blue on the rocker panels, like the Ford F series back in the 70's.. Light green was the worst on 1 car..
GrizzlysGhost
Montana
I've seen a Hummer done up like that using standard matte bedliner spray; looked great!
