Has Slate announced their battery choices already?Would be interesting to know if LFP will be used on both standard and long range. I'm thinking to get the longer range they'll probably need to stay with the higher density NMC.
Mike the Car Geek knows a guy (Mark Phelan) who says that it came to him directly from the CEO.Has Slate announced their battery choices already?
Again, I'm going to double down and wager that Phelan just made that factoid up and himself doubled down on it when Mike pressed him for details. That would've been an incomprehensibly strange way to bury the lede on what might be the biggest reveal that Slate's had since the April 2025 reveal.Mike the Car Geek knows a guy (Mark Phelan) who says that it came to him directly from the CEO.
But for some reason, this "veteran journalist" did not apparently think the announcement was remarkable in any way and didn't even bother to quote the CEO in his article.
The strength of NMC and weakness of LFP is density though. The difference in density is right about where using a LFP of the same size as the extended range NMC gets you the standard range. If they had gone LFP from the start, without raising the bed and reducing the cargo capacity, the max range option would have been 150.Again, I'm going to double down and wager that Phelan just made that factoid up and himself doubled down on it when Mike pressed him for details. That would've been an incomprehensibly strange way to bury the lede on what might be the biggest reveal that Slate's had since the April 2025 reveal.
The series C funding was important, the executive team shuffle was notable, various drips and dregs of clarification from the chat team and snapshots from videos were interesting, but I've seen no other major fundamental changes since the initial reveal.
IMO, Slate's weakest feature has always been the NMC battery. Maybe the tow capacity for some, and maybe the cost of the SUV kit for others, but probably the battery. Going to LFP would reduce the cost and also resolve a ton of cell degradation concerns!
That is what I want to know as well. If the long range is LFP also then it is an easy decision for me, I’m getting the long range. However, if the long range is NMC and standard range is LFP it will be a tougher decision.Would be interesting to know if LFP will be used on both standard and long range. I'm thinking to get the longer range they'll probably need to stay with the higher density NMC.
The thing about pricing is they're going to charge what people will pay.That is what I want to know as well. If the long range is LFP also then it is an easy decision for me, I’m getting the long range. However, if the long range is NMC and standard range is LFP it will be a tougher decision.
Slate did tell 1 forum member that the extended range would be cheaper than the SUV kit at $5k. So if we just set $4k as the probable price of the extended range does it seem reasonable that it would be that low to credit 53kWh of LFP and buy 84kWh of NMC and the net difference would be $4k. For me I would think a chemistry change would result in a bigger delta than $4k which could indicate that both standard and extended range are same chemistry.
According to at least one article I've read, the new extended range battery option has been eliminated. Instead, they've extended the range of the new battery to a true 205 miles. Moreover, it will supposedly be safe to charge it to 100% and use it to 0% without negatively impacting the battery life. Haven't heard how it will be impacted by high speed charging. I'll be doing 90% of my charging at home, so it's not really much of an issue for me.Has Slate announced their battery choices already?
