GreatLakes
F150 ā€˜16 supercab longbed! V8
Something's a bit "off" about the rear tire in the photo.
I don't see what you mean. That you don't see the bottom few inches of the tire?
I just thought it was a dirt track, and that wheel is running in a rut.
Are the sticks down to the axle measuring up-down motion of the wheel, for testing suspension?
Yes. The front tire is on the surface and a couple of inches of the rear tire are visually missing and sunken into the painterly road surface.
Detroit, MI
www.youtube.com
Ford Mach-E
The photo is definitely of the Test Mule Vehicle, not the production prototypes.
Cascadia Motion is not a high volume manufacturer of Electric Motors. Most of what I've seen them do are niche or low-volume commercial vehicles. Not to say they couldn't ramp up, but they were likely selected as an off-the-shelf option to get the early mule trucks running.
Did you notice in the specifications that it is water-cooled, and has limited slip? I kind of figured it would be air cooled, not water cooled. Of course this is just a prototype. On more expensive cars, do they use this while it is being driven to warm the batteries in cold weather? I understand the batteries don't do as good in cold weather. I think Lucid batteries are heated with a fluid.
evtruth
PlugLyf
Warsaw, IN
linktr.ee
Water cooled is good, historically air cooled batteries tend to not perform well.
Correct, using Tesla as an example, the batteries are heated with liquid coolant, particularly when preconditioning is invoked for charging.
John5964
Middle Georgia
F150 JeepJK
Limited Slip stays I hope. It would be better than Traction Control for the surfaces I will be driving on.
JoeUser
Joe
Polestar 2, Mazda b2300
My company work with Cascadia motors. They are fantastic, but... that motor/inverter would be easily $15k+ off-the-shelf. Even with a significant volume discount I don't think it would come close to the price point slate needs.
Also it is definitely not a Cascadia motor installed in the more complete prototypes.
Slate Auto Pickup Truck Drive Unit / Motor supplier appears as Cascadia Motion (BorgWarner) in Slate prototype video 1751723272137-9m
If that is even actually a shot from Slate, it's likely they were just using Cascadia for early prototypes.
Seeing as the Cascadia motors were used for the prototypes , it would be interesting to see if one could be swapped in to a production slate. We'll have to see.
