Is ~150 mile range adequate for a fleet vehicle ?
Slate has often suggested in their media reveals that their vehicles would be perfect for fleet sales, e.g. delivery services, home repair contractor, property management, commercial plumbing, HVAC and electrical contractors, etc.
The Slate sanctioned commercial “Human Grade” presents an entertaining story on a “family-run” business.…
The question remains, is the standard range adequate for commercial/ fleet usage? My take is that even the larger battery might be a bit strained in a heavy use case.
Wondering if there are serious concerns for those considering a Slate for small business ventures.
Johnny-Longtorso
Don
Tampa
I would say it depends on the area - for something like an appliance repair company that should be more than adequate in most metro areas.
I would say the more rural the service area of a given fleet the less likely this is a good match.
But then you can have a mixed fleet - something like the Slate would be an idea "parts runner"
Plugging in some numbers out of curiosity, it takes about 15 miles to go from one end of my town to the other, so a 30 mile round trip. They'd be getting about 5 round trips on a full charge.
I wouldn't be surprised if the MO at most fleet sites would be to plug the thing in whenever it's not in use, that's what they do at my work with the powered pallet jacks and forklifts if they remember to.
I've got to drop off some used fluids at O'Reilly's later this week, I'll have to ask how often they use those parts runners there.
It’s been my experience is that nobody remembers to plug in and recharge pallet jacks, forklifts, etc. And when it’s time for you to use it, the charge is nearly empty. This mindset needs to change with a Slate in your fleet.
JeffVA
Jeff
Roanoke VA
F-150
Depends on many factors. You should only charge these batteries to 80% which means 120 miles. Below 32 is May only be half that which will still work for many businesses. Larger battery would be better.
TRP
Louisville KY
Mach E
You need to keep in mind the EPA estimates are a combined city and high way driving. Most fleet drivers/pats runners/whatever would be city driving. City driving will net higher ranges than ICE vehicles because there's no idling. Add in regenerative braking and 150 miles would be just fine. Charge up over night and repeat.
As an example my Mach E AWD gets 2.8 on the highway at 75 and I can get 5.2 easily in the city
Slater
Spring Hill Florida
2020 Tesla Model 3 Long Range
I think it’s enough for contractors like plumbing, electrical, air conditioning, in which you need to bring your tools to a job site. It is not enough for rideshare or delivery services being on the go all day. And generally the usable range is around 50% of the advertised range, for those that charge to 80% and run it down to 20% and accounting 10% loss for less than perfect driving and conditions. So the small battery is good for about 75miles, maybe up to 100 miles, before recharging.
Totally agree with your statement. While I originally thought that the Slate could be used as an Uber, the reality quickly set in. The concept of rideshare is seriously flawed with o 2-door vehicle. No Uber driver is going to 'share' the front row with a riding passenger. Not happening.
Slater
Spring Hill Florida
I do rideshare and food deliveries in my Tesla and it’s ideal in those scenarios. No way a Slate could manage it with the ranges currently being offered. Also agree, definitely not a car for passenger rides (not even sure they allow two door cars on the platform).
I will say that the ranges they are giving for the battery capacities seem low. It could be that Slate prefers the under promise and over deliver approach, a stark difference to how Elon operates. It could also be the difference in battery chemistry. Will be nice to see some real world tests.
The use case for an EV greatly affects the actual range it will provide. As mentioned earlier, the eMPG listed on the sticker is determined under a controlled environment and represents a ‘combined’ total.
The slate, or any other EV, will deliver far more mi per kWh if used exclusively in an in city driving environment. For example my F150 Lightning gets 1.8-2.1 mi per kWh on the highway at 70-72mph here in KY’s rolling hills. However, I can get 2.8-3.0 when driving around town or on the back roads running 35-45 mph.
Do the math. It will work well for city driving deliveries.
Ford Transit EV has about the same range and I see many fleet companies use them in the city where I am.
Slate Auto Pickup Truck Is ~150 mile range adequate for a fleet vehicle ? hq720
Plus I see them at Tesla Superchargers charging up during the day and watch the employees take their lunch while charging.
J
VT
Rivian R1S
It will really depend on what the fleet is doing, and how big the service area is.
Most existing fleets will already have someone that knows how far each vehicle travels on average per day in service. They will be a little less sure of what a maximum travel day looks like as opposed to an average. Many will have records they can look at though.
It is highly likely when fleets purchase EVs they know exactly what will “do the job” and are not buying something that won’t, and many fleet EVs are around that range (Amazon’s delivery vans from Rivian were designed for Amazon and have that range). That doesn’t mean there isn’t a lot of business that would need “just a bit more” or “Way more”, merely that there are a lot that are well served by that range.
Mostly yes it’s usually from a warehouse/distribution to a commercial property I do the landscape for some Budweiser distributors and they have some trucks for offsite maintenance and small delivery vans and usually it’s only for small distances but major delivery are handled by the sumo trucks to bigger stores
