Heated Seats Covers??? Motor Trend article: "Automotive Designer Tisha Johnson and Slate Auto: The Perfect Match"
thommeigh
Tom
Providence, RI
2013 Toyota Prius
Article link here!
This was an interesting read... wanted to share it here though because the article mentioned that you can add a cover for heated seats. Do we know this to be true?I checked the Slate Maker but didn't see anything. I had sent that question into Slate a while back and they responded that it was something they were thinking about. Just curious if I missed something.
They have mentioned a heated seat cover several times. Which would imply they've engineered the electrical system to make it an easy plug in (one would hope).
What's the voltage, I wonder?
It's more efficient to run seat heaters directly from the 400-Volt battery. However, it's easier and safer to run it off 12-volts.
There is no way I'd run the 400V HV circuit up into the passenger compartment, let alone 5mm from my balls.
Any inefficiency from using 12v instead of pack voltage is just more heat, which is the point. Plus 12v aftermarket seat heaters have already existed for decades and are very cheap.
RedJoker
Ford Transit Connect
This is where I'm hesitant. The last heated seat cover I bought shorted out and melted a few things. I'm not sure I like "cheap" in this scenario.
I don't have a long winter like you northern people, but man do I love my heated seats and steering wheel on my Maverick in January and February. If either or both are offered as accessories I am SO in.
Bonus heat
Agreed, they are very nice on my MachE as well, and have the very practical effect of improving winter range - if you can keep the cabin cooler because you are heating your hands and body directly, you use a lot less climate-control energy.
jonboy108
Jon
florida
tesla y
I installed aftermarket seat heaters on an old Chevy Tahoe, bought the best ones I could find and worked like a champ for ten years. might do that to my slate
It’s a contest for me. I turn ventilation off and seat heaters on and see how long I can go before turning the ventilation on. Usually when I turn the ventilation on it is due to a windows fogging issue and not because I was too cold.
I did this a lot in my Spark.
As long as a couple of those things weren't your balls.
