bed drainage, bed ventilation
solartogo
Glenn
NV
Scion xB, F-150
I was thinking a bit about a bed cover on the Slate, and assuming the cover is somewhat watertight, was wondering how hot it would get under the cover, and whether there would be other ventilation.
Or if water got it while the cover was open, if it could drain out, other than by going up hill, and assuming that the tailgate isn't totally water tight.
Cubicle23
Joe
Northern Maine
25 Forrester, 12 Scion
In the things I have seen the tailgate is most definitely not air/water tight. Production models may have additional seals along the hinge line but , as @007 says, not a concern
There was a neat video in the Reddit AMA:
Dumped ten gallons of water in the front of the bed that drained without leaking anywhere that water isn't supposed to be.
There is a pretty good gap between the bottom of the tailgate and the bed on the prototypes from what has been reported.
Pretty sure it will need to be for the SUV versions though. May come with a tailgate seal when you get the SUV kit.
solartogo
Glenn
NV
Scion xB, F-150
Would sure like to see this video.... can't figure out where to click to get to it.
Huh, the embed broke the video? Not sure how to make the forum not create a media tag, does this work?
Link to post
BCondrey
Barry
Rivian R1T
I think the question is what bed cover can we get that doesn't leak.
Unfortunately, the forum header picture cycles through a few including the OLD design of the bed footwell. It looks like there are about 5 ways to cause leaks. Probably true, so changes were made.
This is not the latest design:
Slate Auto Pickup Truck bed drainage, bed ventilation 1787597976526-ym
solartogo
Glenn
NV
Scion xB, F-150
No, the question was what happens when water gets into the bed, in spite of getting a bed cover that doesn't leak, because sometimes you have to open the cover while it is raining.
Of course, what you thought the question was is also interesting.
