Is there a 12v volt source in the frunk?
Imhotep
2008 Prius
Is there a 12 volt source in the frunk?
There was a 12V in the frunk of the beta Slate I saw at the Space Needle yesterday. Right next to the light on the passenger side. I was joking with the Slate rep about smoking and drinking out of the frunk. Having said that, this particular Slate did not have a drain hole for the frunk cooler feature. Prototype disclaimer.
12v outlet or 12v battery? I ask because more than one person on this forum has claimed that Slate is including a 12v battery. I’ll believe it when I see it. Until then I’m going with a voltage step down converter.
Imhotep
2008 Prius
Both. There is a 12V battery under the frunk cover on the passenger side and a few inches from that is a 12V cigarette lighter style outlet. The Slate rep would not let me look inside the fuse box which was also near by. There is also a 12V cigarette lighter in the dash between the center and RH flip up doors and two USB-A jacks on the LH side of the center compartment of the dash. Disclaimer: I was looking at a prototype.
I see it. Is that a LiFePO4 12v battery?
Lead acid more than likely, much cheaper and I believe I see the fill ports on top.
They use the 12v battery as a buffer for the DC-DC converter.
2005 Pontiac GTO
It’s also pretty much a requirement. The low voltage system is what does all the safety checks before closing the contactors and enabling high voltage. It’s what does the handshake for charging, and in the event that a crash occurs, is what closes the contactors, disabling the HV system and then runs the hazard lights, etc.
Tran
Explorer
Hopefully we won't be seeing the same 12v battery issues that's plagued so many other EVs. 🤞
If the battery is a standard flooded lead acid I'll probably swap it out for a AGM unit. Seems to help solve most problems. Hopefully it will just ship with one.
I'm not sure why there isn't just a converter, cost I assume. Lucid still has a separate 12 v battery. I asked Slate Auto, and there is a 12 v battery in the frunk. You can see it in the Munro video in the center of the firewall, but I think it is now located on the passenger side.
DC to DC converters produce an AC ripple that can be dampened by a battery.
Also, the DC converter would have to be on all the time which means it would increase the standby loss. Meaning your battery would drain faster just sitting there.
Having a buffer battery let's you store power so you can turn off everything so standby loses are much lower.
On the side of safety, if the converter died while on the road you would instantly loose all the 12v systems where with a battery you would have some warning.
Could you make a converter system work? Probably, but like you said, it would be more expensive and complex.
JoeUser
Joe
Polestar 2, Mazda b2300
Some older Zero electric motorcycles don't have 12v batteries, so it is possible. But EVs, no matter how cheap or expensive, have ever gone without a 12v. I'm guessing it has to do with regulations on how long a passenger vehicle has to be able to support itself after total failure. I'm guessing motorcycles don't have the same regulation.
Macomb, Michigan
Spoke with a Slate rep at the Detroit event; Drain plug is coming, it also had a 12VDC outlet on the passenger side, Rep said they are working on 120 VAC outlet for that space. To me that would make it a work truck and not just a toy.
