- First Name
- Chip
- Joined
- Apr 25, 2025
- Threads
- 9
- Messages
- 689
- Reaction score
- 757
- Location
- Bellevue WA
- Vehicles
- FJ Cruiser
Assuming the number of cycles is the same (~2000), you get more years of life for the same amount of annual driving (60% more) with the larger battery along with better range per charge cycle. Presumably better resale value too.Would Battery Longevity be another reason to go bigger with the battery?
Even if you don't plan on doing long trips a bigger battery provides ability to keep state-of-charge in the 20-80% range more easily.
Another reason might be because generally speaking it's just less taxing on each individual Battery Cell when there are more cells. 240/150=1.6, so there are 60% more cells doing the same amount of work. (Actually slightly more work because of the additional weight.)
Put another way, if you need to charge less frequently your cells will experience fewer charge cycles over time so they'll last longer.
Doh! 🤦♂️
My question has already been answered.
Another question: Does the bigger, heavier battery reduce payload capacity? Seems like it would.
