What would you tow?!
I’m wondering how hard you all will push the slate because the fact is if it can move the load it well can tow the issue lies in the breaking I own a land scaling business so I’m very curious to see if I could tow my trailers 2 big one mini I bet the mini no problem the big well I’ll let you know if I’m calling the warranty place XD haha
lgerger
MD, USA
Tesla Model Y LR
Local hauling of stuff.
Miked47a
Michael
Woodstock, NY
Mustang Mach-E First Edition
I want to be able to tow my pop-up camper. The poor towing capacity of the Slate Truck may be a deal breaker. My primary vehicle is a Mustang Mach-E, so I can't tow with that.
The most I would tow would be small equipment from a local rental place to my house and back. Things like a small concrete mixer, or lawn aerator.
How about this guideline: If you wouldn't try to tow something with a Chevy Sprint, don't try to tow it with a Slate Truck.
Would you try to tow a 3,000-pound tent trailer with a Chevy Sprint? Of course not because even a lightweight Teardrop Camping Trailer is probably way over the 1000-pound limit, especially when it's packed with gear and camping supplies.
Imagine how hot the Slate's little electric motor will get trying to pull a heavy load up a long hill. Yikes!
Unfortunately if you need a vehicle for towing, the Slate is the wrong horse for your particular course.
nice but would that trailer also have a motor I know a while back a company was toying with that idea idk now
DRugerH
Dan
Kenosha, WI
Nothing... I'll be keeping mu Silverado 2500HD for that purpuse
Dan
slateya
Minnesota
Dan
Same. 2500HD 8.1L, Allison transmission, 4x4 for all things heavy hauling, towing, and gasoline usage. I swear I hear toilet flushing sounds when stepping on the go pedal.
The Slate will be all welcome run around commuter and light hauler.
GreatLakes
F150 ‘16 supercab longbed! V8
Commercial teardrop trailers are out of my price range. They sure do look pretty. There is a reddit group, lots of websites, and at least one book on DIY building. As I understand it, teardrops started after WW2 and were mostly a home built rig for ten or twenty years.
I would hope to build one for < $3000. And have a finished weight under 800 pounds. Maybe 1100# with the fixed gear, the rest can ride in the truck bed. Close enough to fit Slate towing limit in my book.
But I am curious about what the limiting factors are with Slate. Do you think it is overheating the motor?
Hopefully there would be a towing upgrade option. Certainly I think a 4000# vehicle should handle 2000#. Ideally it would get up to Airstream Bambi 16' levels, 2500#. But maybe frontal area figures into it too.
I busted my first two trucks. Making a trash run with '63 F100 rust bucket. Just a normal amount of bagged trash in the bed, but towing my brother-in-law's 10' trailer that maybe had more than it looked like. I look in the side rear view mirror and the driver side wheel is 2' out from the truck. Turns out there was a small metal plate that holds the axle in, it had failed. I did fix it myself I think. The part was cheap.
